hard girkasse galloper
Posted 17 February 2016 - 11:12
Posted 18 February 2016 - 22:55
Kula i underenden av girstanga står i ei plasthylse i overføringa til girkassa. Dersom denne er slitt, vil den kunne bli kranglete. Du vil også kunne merke at girstanga virker slarkete. Er forøvrig ikke noe stort hokus-pokus å skifte denne. Vil anta en liten halvtimes arbeid, alt fra innsiden av bilen.
Posted 19 February 2016 - 11:43
Posted 19 February 2016 - 11:46
Posted 20 February 2016 - 02:05
Posted 20 February 2016 - 17:38
http://www.ebay.ie/i...=item1c4c944cc2
HardKåres Pajeroer
HardKåres Amerikanere
Posted 21 February 2016 - 10:58
Posted 21 February 2016 - 20:32
Posted 09 February 2018 - 18:49
takker for svar , er denne plast hylsa mulig å få kjøpt løs ?
<script pagespeed_no_defer="">//=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty©)return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b{d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if( {var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject©}catch(P){try{l=new ActiveXObject( }catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e( ),l.setRequestHeader(A,E),l.send(a))}};O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.offroad.no/forum/index.php?app=forums&module=ajax§ion=topics&do=quote&t=132287&p=1696602&md5check=92c568bc654c509b55e3f93e52b4a16f&isRte=1,WyQ3C4mRrQ,false,PNF72SePSlk'); //]]></script>[q];++d){var>[q]+d[q])break;a+=d}b=!0}this.e&&(d=x+e(json.stringify(this.h())),131072>[q];++b)for(var>
Enig med pajeroskru... Skru løs gearspakbelgene, så kommer du til festeskruene til gearspakene. Så løfter du gearspakene ut av kassen, og bytter plasthylsa. Bilde her:
<script pagespeed_no_defer="">//=a.offsetWidth&&0>=a.offsetHeight)return!1;a=this.j(a);var c=a.top.toString()+y+a.left.toString();if(this.b.hasOwnProperty©)return!1;this.b[c]=!0;return a.top<=this.c[p]&&a.left<=this.c[m]};O[r].l=function(){for(var a=[F,G],c=[],d={},b=0;b{d=y+e(c[b]);if(131072=a[q]+d[q]&&(a+=d),b=!0);N.criticalImagesBeaconData=a;if( {var c=this.d,b=this.f,l;if(f.XMLHttpRequest)l=new XMLHttpRequest;else if(f.ActiveXObject)try{l=new ActiveXObject©}catch(P){try{l=new ActiveXObject( }catch(Q){}}l&&(l.open(D,c+(-1==c.indexOf(z)?z:t)+L+e( ),l.setRequestHeader(A,E),l.send(a))}};O[r].h=function(){for(var a={},c=h.getElementsByTagName(F),d=0;d=a[b.src].n&&b[p]>=a[b.src].m)a[g]={renderedWidth:b[m],renderedHeight:b[p],originalWidth:b.naturalWidth,originalHeight:b.naturalHeight}}return a};N.k=function(a,c,d,b,g){var k=new O(a,c,d,b,g);M(f,H,function(){f.setTimeout(function(){k.l()},0)})};N.criticalImagesBeaconInit=N.k;})();pagespeed.criticalImagesBeaconInit('/mod_pagespeed_beacon','http://www.offroad.no/forum/index.php?app=forums&module=ajax§ion=topics&do=quote&t=132287&p=1696587&md5check=92c568bc654c509b55e3f93e52b4a16f&isRte=1,WyQ3C4mRrQ,false,69VyzbATrPo'); //]]></script>[q];++d){var>[q]+d[q])break;a+=d}b=!0}this.e&&(d=x+e(json.stringify(this.h())),131072>[q];++b)for(var>
Kor fant dere denne plasthylsa ? Min girstang er ganske så slarkete så skulle fått ordna de.
Posted 12 February 2018 - 15:38
Plast biten får du hos forhandler, kjøpte en der selv er billig. ville sjekket olje nivå, og byttet til syntetisk olje på kassa
Posted 15 June 2018 - 21:48
