Startet Tahoen 03 i dag, og plutselig var det et annet språk i instumentet... noen som vet hvordan man får det tilbake til engelsk?
Tahoe 03 språk
Tahoechase
, Dec 09 2018 23:08
1 reply to this topic
Posted 09 December 2018 - 23:08
Posted 10 December 2018 - 19:41
Muligens dette kan hjelpe deg. Er sakset fra internet
https://itstillruns....oe-7208356.html
How to Reset the Language on a 2003 Tahoe
by Leonardo R. Grabkowski
The 2003 Chevrolet Tahoe is equipped with a driver's information center. This center consists of a selection menu in your odometer and controls on either side of your steering wheel. One of the options for the information center is the display language. The Tahoe is available in English, Spanish or French. If someone has set the language to one that you aren't familiar with, you can simply reset the display language by selecting the desired language from the menu.
Push the "Personalization" button on the right side of your Tahoe's steering wheel. This button is not labeled with text; it shows an icon of a sheet of paper. Press the button several times, until "Display Language" appears in the odometer.
Push the "Select" button several times to browse through the available languages. The "Select" button shows an icon of a left-facing arrow.
Stop pressing "Select" when the desired language is shown. For example, if you wanted to reset the language to "English," stop on "English."
Push the "Personalization" button once to select the displayed language. This returns the odometer to the standard viewing mode. Your language is now reset to English.
TipYour Tahoe's engine must be running, or the key must be turned to "On" to be able to access the information center.
