Her vil jeg lage ett arkiv over nyttige linker.
Kom med forslag så redigerer jeg dem inn etter hvert.
Motor
Gear-transfer-aksler
Longfield drivknuter:
http://www.toyotaoff...d/Longfield.htm
http://www.longfieldsuperaxles.com/
http://www.pirate4x4...ght=c-clip weld
Mer om Toyota knuter:
http://4x4wire.com/t...iews/profields/
Diverse om gear & transfer:
http://www.high-impa...ms_Approach.htm
Alt om mellomaksler:
http://www.pirate4x4...haft/index.html
Powertrax locker:
http://rockcrawler.c...front/index.asp
http://rockcrawler.c...ax_tj/index.htm
Info om fordelingskasser:
http://homepage.mac....oahlmil/t_case/
Dekk & felg
Litt om Beadlocks:
http://www.pirate4x4...s/Beadlocks.htm
http://rockcrawler.c...locks/index.asp
http://www.alliedroc...om/articles.htm
http://www.pirate4x4...ad.php?t=341141
Krawler:
http://rockcrawler.c...eview/index.asp
BFGoodrich Mud-Terrain T/A KM
http://rockcrawler.c...gmtkm/index.asp
Goodyear MT/R
http://rockcrawler.c...mtr35/index.asp
Baja Claw:
http://rockcrawler.c...5bias/index.htm
Oppheng-fjæring-dempere
Masse om oppheng:http://www.pirate4x4...ad.php?t=168577
Veltevinkler m.m.
http://www.jeepaholics.com/tech/cog/
Ramme-karosseri-bur
Bur:
http://www.pirate4x4...tube/index.html
Styring
Orbitrolstyring:
http://www.pirate4x4...ing/index3.html
Div om styring:
[urlhttp://www.pirate4x4.com/tech/billavista/Steering/Steering_Index/SteeringIndex.htm[/url]
RockRam:
http://rockcrawler.c...am_tj/index.asp
Bremser
Styrebrems:
http://cncbrakes.com...452A&subseries=
Koblingskjema for styrebrems:
http://home.c2i.net/...0Styrebrems.doc
Utstyr
Brytere:
http://www.extremeve...s/stickintj.htm
Håndgass:
http://rockcrawler.c...ottle/index.htm
Håndgass:
http://rockcrawler.c...hrottle/re1.htm
Diverse
Litt om bolter:
http://rockcrawler.c...eners/index.asp
Kalkulatorer
RTI (Ramp Travel Index) kalkulator:
http://www.suzukiinf...isc/rti/rti.htm
Div kalkulatorer for utveksling, fart og dekk:
http://members.optus...n/gearcalc.html
Kalkulator for tiltrekkingsmoment (tommer):
http://www.rockcrawl...rque/index.asp#
Butikker
[url]http://www.polyperformance.com/shop/home.php
[url="http://www.4x4butikken.no/"]http://www.4x4butikken.no/
http://www.4x4supply.no/
Litt av hvert
Absorber Synthetic chamois http://www.theabsorber.com
AC Delco GM chrome products http://www.proformparts.com
Accel Ignition products P http://www.mrgasket.com
ACT Clutches Performance clutches P http://www.advancedclutch.com
Addco Anti-sway bars P http://www.addco.net
AEM Import performance P http://www.aempower.com
Aeromotive Performance fuel systems P http://www.aeromotiveinc.com
Aeroquip Braided hose & fittings P http://www.aeroquip.com
AFE Air intake systems P http://www.afefilter.com
Airaid Air intake systems P http://www.airaid.com/
Airflow Research Cylinder heads P http://www.airflowresearch.com
Air Ride Technolgies Air suspension http://www.ridetech.com
APC Automotive accessories P http://www.performan...yleattitude.com
ARP Engine fasteners P http://www.arp-bolts.com
ATI Performance Transmission components P http://www.atiperformanceproducts.com
Auburn Gear Differential components P http://www.auburngear.com
Auto Art Diecast Diecast replicas http://www.autoartmodels.com
Auto Custom Carpets Replacement carpet kits http://www.accmats.com
Auto Specialties Underdrive pulleys P http://www.aspracing.com
Auto Ventshade Exterior styling P http://www.autoventshade.com
Autometer Automotive gauges P http://www.autometer.com
Autotecnica Automotive accessories P http://www.autotecnica.com
B&M Shifters & transmission products P http://www.bmracing.com
Baer Brake Performance brake systems http://www.baer.com
Banks Engineering Diesel performance http://www.bankspower.com
Barry Grant Fuel systems & components P http://www.bgfuel.com
BBK Throttle bodies, headers & related P http://www.bbkperformance.com
BeCool Performance radiators P http://www.becool.com
BellTech Suspension components P http://www.belltechcorp.com
Borla Stainless steel exhaust products P http://www.borla.com
Brodix Cylinder heads & blocks http://www.brodix.com
Bullydog Diesel performance P http://www.bullydog.com
C&L Ford mass-air meters P http://www.cnlperformance.com
California Car Duster Car care products P http://www.calcarduster.com
Centerforce Performance clutches P http://www.centerforce.com
Centerline Aluminum wheels P http://www.centerlinewheels.com
Cloyes Timing components http://www.cloyes.com
Comp Cams Camshafts & valvetrain components P http://www.compcams.com
Corsa Performance Performance exhaust http://www.corsaperformance.com
Crane Cams Camshafts & valvetrain components P http://www.cranecams.com
Crower Camshafts & valvetrain components P http://www.crower.com
CSR Performance Electric water pumps P http://www.csiperformance.com
Dart Machine Cylinder heads & blocks http://www.dartheads.com
DC Sports Import performance P http://www.dcsports.com
Demon Carburetion Performance carburetors P http://www.bgfuel.com
Design Engineering Thermal protection P http://www.designengineering.com
Doug's Headers Headers & exhaust products http://www.dougsheaders.com
Eagle Cranks, rods & stroker kits P http://www.eaglerod.com
Earls Braided hose & fittings P http://www.holley.com
Eaton Traction Differential components P http://www.traction.eaton.com
Edelbrock Performance products P http://www.edelbrock.com
Edge Products Diesel performance P http://www.edgeproductsinc.com
Energy Suspension Polyurethane bushings P http://www.energysuspension.com
Eradispeed Performance brake systems P http://www.eradispeed.com
Erson Cams Camshafts & valvetrain components P http://www.mrgasket.com
Ertl Diecast Diecast replicas http://www.ertltoys.com
FAST Electronics Fuel injection control systems P http://www.fuelairspark.com
Federal Mogul Engine components P http://www.federal-mogul.com
Fel-Pro Performance gaskets P http://www.federal-mogul.com
Flaming River Streetrod components http://www.flamingriver.com
Flex-a-lite Automotive cooling products P http://www.flex-a-lite.com
Flowmaster Performance exhaust P http://www.flowmastermufflers.com
Flow-Tech Performance exhaust P http://www.holley.com
Fluidampr Harmonic dampers P http://www.fluidampr.com
Ford Racing Ford performance parts P http://www.fordracingparts.com
Geddex Dial-in marker & other trackside items P http://www.geddex.com
GMP Diecast Diecast replicas P http://www.gmpdiecast.com
Granatelli Mass-air meters & Diablosport tuners P http://www.granatellimotorsports.com
Grant Steering wheels & accessories P http://www.grantproducts.com
Greddy Import performance P http://www.greddy.com
Green Filters Performance air filters http://www.greenfilterusa.com
Ground Force Suspension components P http://www.groundforce.com
G-Sport Import accessories P http://www.mrgasket.com
G-Tech Performance meters P http://www.gtechpro.com
Hawk Brake Performance brake pads P http://www.hawkperformance.com
Hayden Automotive cooling products P http://www.haydenauto.com
Haynes Automotive manuals P http://www.haynes.com
Hays Performance clutches P http://www.mrgasket.com
Hedman Hedders Performance exhaust P http://www.hedman.com
Helix Throttle body spacers & air intake kits http://www.streetand...lectronics.com/
Hellwig Suspension Suspension components http://www.hellwigproducts.com
Highway 61 Diecast Diecast replicas P http://www.ffertl3.com
Hitachi Automotive Chrome alternators P http://www.hap-la.com
Holley Performance products P http://www.holley.com
Hooker Headers Performance exhaust P http://www.holley.com
Hotchkis Suspension components P http://www.hotchkis.net
HP Books How-to & performance books P http://www.penguinputnam.com
Hurst Shifters & transmission products P http://www.mrgasket.com
Husler Headers Race exhaust products http://www.hedman.com
Hypertech Performance computer upgrades P http://www.hypertech-inc.com
Innovate Motorsports Digital tuning http://www.innovatemotorsports.com
Jacobs Electronics Performance ignition P http://www.mrgasket.com
Jada Toys Diecast Diecast replicas P http://www.jadatoys.com
Jaz Products Seats & fuel cells P http://www.jazproducts.com
JBA Headers Performance exhaust P http://www.jbaheaders.com
JE Pistons Pistons P http://www.jepistons.com
Jet Performance computer upgrades P http://www.jetchip.com
JP Performance Billet timing components P http://www.jp.com.au
K&N Air filter & intake systems P http://www.knfilters.com
Keith Black Pistons Pistons P http://www.kb-silvolite.com
Kirkey Racing seats P http://www.kirkeyracing.com
Koni Performance shocks P http://www.koni-na.com
Lakewood Bellhousings & suspension components P http://www.mrgasket.com
Lokar Shifters & other streetrod components P http://www.lokar.com
Lunati Camshafts & valvetrain components P http://www.holley.com
MAC Products Ford performance parts P http://www.macperformance.com
Magnaflow Exhaust Performance exhaust P http://www.magnaflow.com
Maisto Diecast replicas http://www.maisto.com
Mallory Ignition Performance ignition P http://www.mrgasket.com
Manhattan Oil Fuel fragrances P
Manley Valves & engine components P http://www.manleyperformance.com
March Underdrive pulleys P http://www.marchperf.com
McLeod Performance clutches P http://www.mcleodind.com
Mechanix Wear Mechanics gloves P http://www.mechanixwear.com
Meguiars Car care products P http://www.meguiars.com
Melling Oil pumps P http://www.melling.com
MIC Diecast replicas http://www.mic-store.com
Michigan 77 Engine bearings P http://www.engineparts.com
Mickey Thompson Street & strip tires P http://www.mickeythompsontires.com
Milodon Oil pans & other engine components P http://www.milodon.net
Moroso Oil pans & other engine components P http://www.moroso.com
Moser Performance differential products P http://www.moserengineering.com
Motive Gear Differential components P http://www.motivegear.com
Motorbooks How-to & performance books P http://www.motorbooks.com
Mr. Gasket Gaskets & other auto accessories P http://www.mrgasket.com
MSD Performance ignition P http://www.msdignition.com
Muscle Machines Diecast replicas P http://www.musclemachines.com
9+ Performance differential products P http://www.new9inch.com
Nology Performance ignition P http://www.nology.com
NOS Nitrous oxide systems P http://www.holley.com
Optima Dry cell batteries P http://www.optimabatteries.com
Pacesetter Performance exhaust P http://www.pacesetterexhaust.com
Painless Performance Wiring harnesses & components P http://www.painlessperformance.com
Patriot Exhaust Performance exhaust P http://www.pertronix.com
Paxton Superchargers Centrifugal superchargers P http://www.paxtonauto.com
Performance Automatic Ford transmission components P http://www.performanceautomatic.com
Performance World Fuel pumps,fasteners & other items P
Permatex Octane boost & other chemicals P http://www.permatex.com
Pertronix Performance ignition P http://www.pertronix.com
Pete Jackson Gear drives P
Pioneer Engine components P http://www.pioneerautoinc.com
Plasticolor Garage stools & floor mats P http://www.plasticolorinc.com
Power Slot Slotted brake rotors P http://www.powerslot.com
Power Stop Cross-drilled brake rotors P http://www.autospecialty.com
Powerbond Harmonic dampers P http://www.precisionparts.com.au
Powerdyne Centrifugal superchargers P http://www.powerdyne.com
Powermaster Performance starters & alternators P http://www.powermastermotorsports.com
Powertrax Performance differential products P http://www.powertrax.com
Probe Pistons P http://www.probeindustries.com
Pro-Blend Chemicals P http://www.pro-blend.com
Procharger Centrifugal superchargers P http://www.procharger.com
Professional Products Intake manifolds,fuel systems & related P http://www.professional-products.com
Proform Engine building tools & other products P http://www.proformparts.com
QA1 Performance suspension http://www.qa1.net
Race Shop Air inlet ducting P http://www.raceshopsupply.com
Ram Clutches Performance clutches P http://www.ramclutches.com
RCI Seats, fuel cells & safety equipment P http://www.rciracing.com
Redline Oil Synthetic lubricants P http://www.redlineoil.com
Richmond Gear Performance differential & transmission P http://www.richmondgear.com
Ringers Gloves Mechanics gloves http://www.ringersgloves.com
RJS Safety equipment P http://www.rjsracing.com
Roadmax Lighting P http://www.roadmaxauto.com
Ron's Fuel Injection Alcohol injection systems P http://www.ronsfuel.com
Royal Purple Synthetic lubricants P http://www.synerlec.com
Russell Braided hose & fittings P http://www.russellperformance.com
SA Design Books How-to & performance books P http://www.cartechbooks.com
Sanderson Headers Streetrod headers P http://www.sandersonheaders.com
Scat Crankshafts Cranks, rods & stroker kits P http://www.scatcrankshafts.com
SCE Gaskets Copper head & header gaskets P http://www.scegaskets.com
Sealed Power Engine components P http://www.federal-mogul.com
Spectre Automotive accessories P http://www.spectreperformance.com
Sprint Suspension Suspension components P http://www.sprintspring.com
SRP Pistons P http://www.jepistons.com
Stage 8 Fasteners Locking fasteners P http://www.stage8.com
Stainless Steel Brakes Performance brake systems P http://www.stainlesssteelbrakes.com
Stewart Water pumps P http://www.stewartcomponents.com
Supercar Collectibles Diecast replicas http://www.supercar1.com
Super Sunny Chrome & aluminum accessories P http://www.super-specialty.com
Superchips Performance computer upgrades P http://www.superchips.com
Suspension Techniques Suspension components P http://www.stracing.com
TA Performance Differential girdles P http://www.taperformance.com
Tavia Timing tabs & engine building equipment P http://www.tavia.com
Taxor Watches & clocks P http://www.taxor.com
Taylor Cable Performance ignition products P http://www.taylorvertex.com
TCI Transmissions & components P http://www.tciauto.com
Thermo-Tec Thermal protection P http://www.thermotec.com
Token Fiberglass Fiberglass components P http://www.tokenfiberglass.com
Torco Synthetic lubricants P http://www.torcousa.com
Trans-dapt Automotive accessories P http://www.tdperformance.com
Trick Flow Heads, intakes & related components P http://www.trickflow.com
Turbonetics Turbochargers P http://www.turboneticsinc.com
VHT Paints & chemicals P http://www.pjhbrands.com
Vibrant Import performance P http://www.vibrantpower.com
Vintage Air Air conditioning kits & components P http://www.vintageair.com
Vortech Centrifugal superchargers P http://www.vortechsuperchargers.com
Weiand Intake manifolds & superchargers P http://www.holley.com
Weld Racing Aluminum wheels http://www.weldracing.com
Wilwood Performance brake systems P http://www.wilwood.com
Wolf Car covers P http://www.wolfautomotive.com
World Products Cylinder heads & blocks P http://www.worldcastings.com
Yella Terra Shaft mount roller rocker systems P http://www.yellaterra.com.au
Zex Nitrous oxide systems P http://www.zex.com
ZoopSeal Inc. Metal protection P http://www.zoops.com
Hardcore linker
RockStar
, Jan 29 2005 00:00
6 replies to this topic
Posted 29 January 2005 - 00:00
6x6: www.usa6x6.com
Land Rover 109" Ex-mil
Posted 30 January 2005 - 00:00
Dana/spicer's hjemmeside
http://www2.dana.com/expert/
Frank
'77 Wagoneer (AMC 360, D60 f&b, ARB, spiraler, +++)
'77 J20 (AMC 258, TBI, D44, D60)
'03 King Cab
"alt kan hjemmelages"
Frank
'03 King Cab
Posted 24 March 2005 - 00:00
det er ikke helt teknisk, men det er 4x4 og det er nyttig!
http://www.off-road....06/unstuck.html - hvordan komme seg løs
1988 Chevy Subb 6.2D - th400 - 208 - 265/75-16 | Garasj: http://www.offroad.n...=ShowID&ID=3157
1978/80 Chevy Blazer K5 - 305/350 LPG - th350
Posted 12 March 2005 - 00:00
når det gjelder V8 maskiner så er denne beskrivelsen/linken helt suveren..
http://www.acctrondh...kselerasjon.htm
http://www.bilbyggin...p?t=104&start=0
DAMER, Tron er singel....OG Prospect i Team Antistress...
Posted 02 April 2005 - 23:00
Hydraulikk og div el:
www.okonomi-deler.no
