(english sorry) just a question
hi, i can't spell or read norwegian (trying to learn though- all my relatives are norwegian, so i should learn it) i'm asking this in english and not through a translator because i am aware that a lot of you are taught english in school, so hopefully someone will be able to answer this
what i am asking is, when looking at a thread, how do i get the thread to be in full version as default? at the moment, when i click on a thread, i have to click on each post individually to view it
cheers from Australia
Hi - and welcome.
This is a "Windows" question and is probably not relatet to Offroad Forum.
Hold down the Shift button when you click a thread and it opens i a new window.
You will then be able to open this in full window.
When you close down Windows, it will normally remember last configuration and open like this next time- in full size.
Try this. Good luck.
valg ----> standard
HAR LYSTPÅ SKIKKELIG 4X4 IGJEN....
<!--quoteo(post=1482817:date=22 Nov 2008, 17:22:name=svk)-->QUOTE(svk @ 22 Nov 2008, 17:22) <{POST_SNAPBACK}><!--quotec-->valg ----> standard<!--QuoteEnd--><!--QuoteEEnd-->
Cheers Mate!
As SVK says, in your upper right corner on the screen you see a button named "VALG" (board choices). Click on it, and a curtain-sub-menu opens downwards. Then you see "Visningsmåte" (viewing options) 3/4 down the menu. Click on "Bytt til: Standard" (Change to: standard), and you should get the best way to view the board.
Good luck!
Regards
Har sagt:
Rygge nei!! Ikke f...!!
Rust kan være pent, det...
ah thanks for that [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img] the valg and visningsmate were exactly what i was looking for [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
i'll figure it all out (and the language) slowly [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img] might take a year or 5 but oh well, it's worth it
btw, i have a question... in the alphabet, where do the åæø sit? (ABCDEFGHIJKLMNOPQRSTUVWXYZ....ÅÆØ?)
ABCDEFGHIJKLMNOPQRSTUVWXYZÆØÅ
_______
how are the extra letters pronounced?
from what i've picked up
Æ - ....?
Ø - OI? OR?
Å - extended A (hold the note a bit longer)
whenever i make a post, i will try to put it in norwegian (please give me a heads up if my wording is completely off), i will be spelling it phonetically though (spell it how it sounds)
cheers
Æ = like the A in MAN and LAND and SAND
Ø = like the U in JUST and MUST and BUST
Å = like the O in OVER and LOW and LOVE
Regards
Har sagt:
chikoroll!
It suprises me that you have ÆØÅ on your computer down under?
When I was in Aus few years back, those three letters where missing on all the computers i could find....
yea, they are missing, i just use the alt + numpad to put them in (alt+145=æ, alt+146=Æ)etc...
