Fsd motstand
hei [Bilde: smile.gif]
Har montert en ny fsd på kjøleribbe,å i den satt det motstand #4..kommer jeg til å merke noe forskjell på den contra en #9???
Takker for svar [Bilde: smile.gif]
tviler sterkt..
Motstanden blir sjekka hver 50. start, så etter max 50 startsykluser vil du merke om det er noen forskjell
Kai
08 Tahoe
14 Tesla Model S
</a>
</a>
</a>
ok da kan den sitte der,Gurba fant noe til meg:
What is the calibration resistor for? It is for setting up the pump when on the test stand. It calibrates the amount of fuel delivered. 1 being the least, and 9 being the most. All the pumps are set within a specific spec. The resistor dials in the last of the calibration to the last little cubic millimeters of fuel. see attached calibration value chart below from TD's files
Can I get more get more power out of my engine if I put a #9 resistor in? Why, yes, but not much. You’ll never notice it one bit. Each number is equivilent to 0.5 cubic millimeters. Note: that is read point 5. So what is point 5 of a cubic millimeter - taint much. That is a whole difference of 0.7% increase. That’ll make you dust that ole grocery getter next time at the light.
There is some theory behind the fact that if you have a higher number resistor, it will hold the solenoid open longer, which means the transistor is on longer. The longer the transistor is on, the more heat it makes. More heat, the less good it is on the PMD. Theory, as said, but worth noting.
