Bilder av skikkelig ødelagt Getrag
Kryssposting på benzworld og jeg har for mye olje i armhulen til å gidde å skrive det en gang til på norsk. MEN her er reultatet av 6 timers skruing sammen med Iver:
Iver460 and I spent the day under my G pulling out my crashed 5-speed Getrag. When we finally got the last bolt out (top left gearbox-bolt is tricky!!!) the sweet smell of burned ATF hit us... In addition to the damages shown in the pictures were:
ATF oil was silver grey with 5mm long brass filings and LOTS of steel particles. Gears and synchros ground to a pulp.
Gearbox input shaft had some play... about 5cm in any direction...
Gearbox housing had burn marks from within. Paint and oily goo was burnt away several places and the steel beneath had gone rusty
And now for those with a strong stomach:
[Bilde: input_shaft.jpg]
Yes! It has melted!
[Bilde: bearings.jpg]
Note in particular the rolling bearing top left. The "rollers" have all been whacked 90 degrees and they do definately NOT roll that way. Also the larger ball bearing has some balls missing. They were not anywhere to be found, not even steel filings...
[Bilde: melted_cover1.jpg]
Backside of the bearings cover. Supposed to be smooth...
[Bilde: melted_cover2.jpg]
Poor lighting, but the aluminium has boiled... Lots of air bubbles, looks like silver lava.
[Bilde: bearing_cover.jpg]
This is supposed to be smooth as well... The deepest groves are about 3mm.
So... to those of you with Getrags with funny noises in them... Now you know whats making the noises [Bilde: fish.gif]
300GD STT 33"
Ja den 5tr kassa va jo nice:mellow:[Bilde: mellow.gif]. Blei nu meget usikker på om jeg burde beholde min 5tr kasse, jeg skal jo inn med min OM617a i kveld..
har jo en grei 4tr kasse som jeg kan bruke. Kan jo kjøpe 33" dekk for å få ned turtallet littTongue, har 31" 10.5 fra før!! Eller er jeg helt på viddene?
Jonny
Ved å gire opp med større dekk øker du belastningen på kassa. Ikke alle har så dårlig erfaring med Getrag GL275 som Tjærand. Ha heller firetrinnskassa i reserve og sett inn den og på med 33" hvis Getrakgen går til hel...
Øyvind
Den går jeg forBig Grin, kom ikke helt i havn med motorbyttet i kveld.
hadde ikke rette verktøyet for å få bytta medbringerplaten, avslutta nu stikker innom MB forhandleren i morra tidlig å låner rette koppen.
Trur jeg kjøper nytt utløserlager m d sammeWink
<b></b><i></i><font size="2"></font id="size2">GD= Min nye hobbyBig Grin
Jonny
