28.04.2005, 23:00
<blockquote id="quote"><font size="1" id="quote"><b id="quote">Kopi av melding:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">Lada Locker that Works and only costs A few Dollars.
Here's a new one for you. " Poor Man's Locker." If you never heard of it think how a farm tractor works. Instead of Duel Pedals I used Dual Handbrakes ? Yes ! it does boggle the mind .
First thing that comes to mind I'm nuts.... Why would I even think of it . Here's the story.
A good friend of mine did the same thing to his Jeep with great success many years ago. Being a skeptic sometimes it can take years of testing before I will put ideas to print. He did and Last Swampswimmer Rally I Tested it to the max. Fantastic response climbing uphill over boulders where my open diff"s would leave wheels spinning in the air. Nice to be able to apply one handbrake to force the spinning wheel to stop and Watch the dead wheel start to turn. 47 trucks started this event and 36 trucks finished. I have to say this Matt and I came in 5th place , Thanks to this simple Idea. Now for those of you who would like to know how we did it. Read on
Parts you will need.
1 One any year Lada Hand brake with short cable ( adjusting nuts )
2 Two Lada Engine lifting brackets
3 Two saddle clamps from your favorite Hardware store. ( for hand brake cable )
4 Four 1/4 20 x 1" bolts and nuts don't forget washers!
Tools you will need.
1 Drill and drill bits
2 Grinder with cutting wheel
3 Some wrenches to tighten nuts and clamps.
Okay position hand brake on floor between existing hand brake and passenger seat. When finished they will be sitting apart approximately 2" . Mirror image is what I mean. Only cut a small piece of the floor out in the same shape as your original handbrake hole. Remove it to make sure of correct location and shape of hole . Place both hand brakes into their holes, now drill new holes in the floor to secure the new one to the truck.
Note you will be cutting through existing floor strengtheners. Don't worry that's why you put washers on both sides of your bolts. NOW's the point of no return , CUT your cable in the center ( the one that goes to both your rear wheels ) Make sure you cut it correctly. ( I used my grinder ) The short adjustable cable you put one end of the engine brackets on. The other lifting hole you put the cable you just cut through and put your saddle clamp on. Note Left cable goes to Left handbrake and Right goes to right. Adjust to suit ....Done ! Its surprising how fast it went together, 3 Hrs max.
Erling
'92 Lada Niva
'03 Ski-Doo Mxz 800 REV x
Suzuki lj50 med kadett motor
Erling
'92 Lada Niva
