Speedometer
hallo, speedometeret har sluttet og telle antall kilometer kjørt. Tror feieln ligger inni speedometer boksen, men kommer ikke in. Hvordan kommer jeg in?
Har noen noe tips her?
its depends what model car you have
if that is mechanical speedometer and if speedometer is showing just kilometers but not speed, or opposit, then you must find another one because the mecahanical part in it is alredy too much used, if problems withh speed indicator , then the same problem just not mechanical but induction problem.
any way uou must change all speedometer or just try to open it and make one good froom several of them if you have more.
it is openeing very simple like fruit bocket:_)
If it seems for you that your offroader is taking too much fuel, it means just one - you must earn more!!!
