The first generation of Chevrolet small-blocks began with the 1955 Chevrolet 265 in³ (4.3 L) V8. But it was the 350 in³ (5.7L) series that set the standard for high performance. The engine's physical dimensions (oversquare 4.00 in bore and 3.48 in stroke, 102 mm by 88 mm) are nearly identical to the 400 hp (300 kW) LS2 engine of today, but of course much has changed. It is by far the most widely used Chevrolet small-block; it has been installed in everything from station wagons to sports cars, in commercial vehicles, and even in boats and (in highly modified form) airplanes!
A 350 is usually common with engine swaps - much of the older, pre-1968 Chevrolet V8s were usually swapped with a later 350 when engine replacement was the norm. It has been known to swap a 350 in place of a 305 since the 350 is part of the same engine family (the external dimensions of a Chevrolet small block are the same).
<b>First usage of the 350 was in the 1967 Chevrolet Camaro and 1968 Nova producing 295 horsepower</b> (gross); other Chevrolet vehicle lines followed suit in the year 1969.
The GM Goodwrench 350 crate motor (sold through Chevrolet dealerships) is based on the pre-1986 small block design with two dipstick locations; pre-1980 on the driver's side and post-1980 on the passenger's side. This motor was produced in Mexico since 1981 as the Targetmaster 350.
Note that Oldsmobile produced an entirely different 350 in³ V8 (4.057 in bore and 3.53 in stroke, 103 mm by 90 mm), the L34 and LF9 from the 1980s.
The 305 variant of the small-block Chevrolet was bored and stroked to 5.0 L (305 in³) with a 3.74 in (95 mm) bore and 3.48 in (88.4 mm) stroke - taken from the 350.
Although the 262 was underpowered (it was not used in other vehicles with a wheelbase greater than 110"), GM engineers decided to increase the 262's bore from its 3.671" diameter to 3.736" while the 3.10" stroke cycle was too short - the solution, incorporating the 3.48" stroke from the 350.
Induction systems included carburetors (both 2 and 4-barrel), throttle-body injection (TBI), tuned-port fuel injection (TPI), and sequential fuel injection (GM Vortec).
After 1996, its usage was limited to light trucks and SUVs as the Vortec 5000.
Year hp (kW) ft·lbf (N·m)
1976 140 250 w/2bbl.
1977 145 245 w/2bbl.
1978 140 240 w/2bbl.
1978 160 235 w/4bbl.
1979 125 235 w/2bbl.
1979 130 245 w/2bbl.
1979 155 225 w/4bbl.
1979 160 235 w/4bbl.
All info hentet fra Wikipedia
Hans Christian
Hilux 85mod, 3" bodylift, 33x12,5x15
