<blockquote id="quote"><font size="1" id="quote"><b id="quote">Kopi av melding:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">Er det mye pæng å spare på gass? (kan evt en dieselmotor bygges til gass?) Slitasje i forhold til bensin/gass?
<i><div align="right">Opprinnelig postet av advance</div id="right"></i>
Du kan kjøre med en blanding av diesel og gass. Jeg mener at du kan blande inn rundt 25% gass. På en diesel vil dette øke effekten noe. Du kan lese mer her:
http://www.lpg-kits.com/
http://www.ilovesponge.com/spongecars/dies...eltechnical.htm
Sitat fra en som har prøvd:
<blockquote id="quote"><font size="1" id="quote"><b id="quote">Kopi av melding:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">I have a 300GD that I had converted to LPG by Gordon Finlay (
http://www.gordonfinlay-lpgconversions.co.uk/). Supply and fit cost was in the region of £1500.
The kit consists of a "black box" fitted to the engine (not sure of technical details) and an LPG tank in the boot plus all the wiring and piping. The black box mixes the LPG with the diesel increasing the combustibility of the diesel (from approx 70% to 90%+) hence improving engine performance and running.
The results were quite impressive all around. I cannot provide quantitative data but:
1. the engine runs far more quietly and smoothly due to improved diesel combustibility
2. performance was noticeably improved especially on the motorway - could be maintaining 70mph up inclines on motorways (engine running temperature was not noticeably affected but to bear in mind that you will be able to drive faster than you normally would so check water levels)
3. fuel economy is noticeably improved around town or cross country; can do between 50 and 60miles off £10 worth of diesel (driving with a light right foot)
4. fuel economy is only slightly improved on motorways - the engine is not economical at these higher speeds and engine revs.</td id="quote"></tr id="quote"></table id="quote"></blockquote id="quote"><font size="2" id="quote"></font id="quote">
Frode
