Ny clutch, Orginal eller noe annet?
Posted 13 August 2006 - 23:00
Jeg tror jeg må bytte.
Hva kjøper jeg?
Orginal eller import?
Skal ut i skogen og opp i trærene også.....
__________
GPS Fantom. Medlem 135 i Suzuki 4x4 Club Norway
Centerforce Dual Friction Clutch.
Change your clutch for the very last time with this ultimate grippers. A must if you have a 1.6 swap or play hard, a great idea if your clutch is starting to wear.
This clutch kit can really stand up to the rigors of serious offroading. They offer greater holding power than any other clutch on the market in the most extreme offroad situation, while at the same time all you to slip the clutch when you need to keep the engine from stalling out on tough uphill obstacles.
The Centerforce Dual Friction Clutch generates up to a 90% increase in holding capacity over stock systems. This clutch/disc set is designed for use with engines producing 'high horsepower and torque' output, or any modified offroad performance vehicle. This system is ideally suited for use with four wheel drive vehicles.
All Centerforce® clutch systems provide smooth engagement and light pedal pressure without compromising high performance.
Centerforce clutches also last far longer than stock replacements. Do not be fooled by other shops selling their super-dee-duper-dee Centerforce copy. This is no copy.... there is no substitution.... the Dual Friction clutch is the undisputed strongest clutch on the market for your Samurai.
Tekst fra www.rocky-road.com
snakkes i bar'n
OPPDAL 4X4
___________________________
Medlem nr:86 Suzuki 4x4 Club Norway
Mvh Frank
Noen sier at de gærne har det godt ,for de vet ikke bedre.
Men de blinde har det bedre, for de ser ikke hva de gærne gjør!!!
Tlf: 47 30 69 00
Grøftekanten Auto.. Nå også internasjonale:D
Er det verd pengene?
__________
men ingen avsettene hos bilxtra passet...
Tlf: 47 30 69 00
Eg kjøpte min pga eg skal ha inn 1600 motor men 1300 svinghjul så eg får ikkje brukt den større 1600 clutchen.
http://www.terrengbil.com
Posted 14 August 2006 - 23:00
Blir ikke noe sånt på meg enda, har en god clutch nå som skal bytte ut den jeg har som slipper taket når jeg gir på
Det er en ring med lodd på som skal øke trykket på platene ved hjelp av sentrifugalkrefter (eller blir det sentripental?) i tilegg til verre belegg, verre fjører og kraftigare alt.
Og så er farge, design, navn og slikt med på å gi den et veldig høgt NIF-tal
Mvh Frank
Men egentlig så skjøner eg ikkje kor dei små puslete lodda skal ha så mykje å seie...
Hadde aldri kjøpt den om det ikkje var for gode erfaringar på andre forum i USA.
Når eg pakka den ut var tilfeldigvis en kompis som driv litt med amcar og racing innom, og han sa berre "wow centerforce clutch"
(Der kom NIF-talet inn )
Kopi av melding:det hørtes i alle fall tøft ut:D
"wow centerforce clutch" Opprinnelig postet av yakuza
http://www.dte-syste...norwegisch.html
#17
Posted 17 August 2006 - 23:00
Det ergrer meg at alt snopet bare finnes til 413, kunne SVÆRT gjerne tenkt meg Centerforce dual friction sjøl!
