Dette må være den beste aksel-løsningen jeg har sett; uavhengig portalaksling!
Beste potensielle off-roadbil?
Stefan E.
, Apr 07 2004 23:00
50 replies to this topic
#41
Posted 11 April 2004 - 23:00
#42
Æ har nok tatt litt feil, både Pinzgauer og Volvo har portalaksler, men bare Pinzgauer har "uavhengig", mens Volvo C303 har stive.
<i><b>Pinzgauer
</b>The Pinzgauer uses solid beam half axles pivoted around the differentials with portal reduction hubs at each wheel station. Each is independently sprung allowing individual wheels to follow the ground contour unaffected by the movement of any other wheel. This design provides exceptional traction and the portal hubs add to the already impressive ground clearance. The reduction hubs are sealed for life to prevent the ingress of mud or water.
<b>Volvo C303</b>
The axles themselves have become somewhat of a legend. The portal axle has a reduction hub at end end that drops the drive, thus increasing ground clearance. The axles also have built-in air-operated diff locks that give the vehicle awesome offroad ability. Following the Volvo tradition, all parts of the C303 are engineered to a very high level and are SERIOUSLY over-built. This is real steel!</i>
<font size="1">Volvo C303</font id="size1">
-93 Hilux
-74 Volvo 142 "Landeveistraktor"
-00 BMW K 1200 LT "Lenestol på 2 hjul"
”Neitakk, æ kjør…”
<i><b>Pinzgauer
<b>Volvo C303</b>
-93 Hilux
”Neitakk, æ kjør…”
#43
Hummer H1 har uavhengig og portaler!!
Tommy Olsen
Tommy Olsen
#44
Hummer`n har vel bare en nedgiringkasse ytterst ved hjulet og derfor sitter drivakseln utafor senter . Bærebrua ligger jo godt neddafor drivakseln så jeg ser ikke grunnen til å kalle det en portal...
#45
Ein gammal kløvhest med sperrer på alle fire er et godt alternativ
#46
Nå blir nok de store guttan med 3og mange tommers hjul, Hummer, Sugge, Fjallasport osv å flire i sjegget, men det får så være.
Æ meine min orginale -93 Hilux x-cab e den perfekte bil. For mæ!
Passe størrelse, passe liten motor (berger meg fra prikker osv...) dekk i tilnærmet orginal størrelse (ikke dyre i innkjøp/ ok kjøreegenskaper)passelig terrengegenskaper som gjør at man ikke treng de store utfordringan får å få testa bilens (og mine) egenskaper. Altså man trenger ikke de store og mest avanserte kjøreområder.
Passelig ok å kjøre på vei, og der er man jo 98% av tia.
Men skulle det gjøres forbedringer, ville de være i denne priorterte rekkefølge:
1 Sperre bak
2 Vinsj, for bruk både foran og bak
3 Litt større hjul
-93 Hilux
”Neitakk, æ kjør…”
1 Sperre bak
3 Litt større hjul
-93 Hilux
”Neitakk, æ kjør…”
#47
<blockquote id="quote"><font size="1" id="quote"><b id="quote">Kopi av melding:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">Nå blir nok de store guttan med 3og mange tommers hjul, Hummer, Sugge, Fjallasport osv å flire i sjegget, men det får så være.
1 Sperre bak
3 Litt større hjul
-93 Hilux
”Neitakk, æ kjør…”
<i><div align="right">Opprinnelig postet av Jama</div id="right"></i>
Jeg synes du ga det perfekte svaret, jeg!
Du har funnet den bilen som DU syns passer for deg, dermed er det den perfekte offroadbilen for deg! Dette er jo fasiten, folkens, å finne bilen som passer til det man skal bruke den til....!
Per
91791531 / 64988722
Per@offroad.no / Ptf@c2i.net
Delespørsmål:23032000
Mfa@offroad.no
1 Sperre bak
3 Litt større hjul
-93 Hilux
”Neitakk, æ kjør…”
Per
91791531 / 64988722
Mfa@offroad.no
#48
enig, et kjempeflott svar
Tommy Olsen
Tommy Olsen
#49
<blockquote id="quote"><font size="1" id="quote"><b id="quote">Kopi av melding:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote"><blockquote id="quote"><font size="1" id="quote"><b id="quote">Kopi av melding:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">Nå blir nok de store guttan med 3og mange tommers hjul, Hummer, Sugge, Fjallasport osv å flire i sjegget, men det får så være.
1 Sperre bak
3 Litt større hjul
-93 Hilux
”Neitakk, æ kjør…”
Per
91791531 / 64988722
Mfa@offroad.no
<i><div align="right">Opprinnelig postet av Per F</div id="right"></i>
<font color="blue">Hmmm, æ bi no nesten rørt....</font id="blue">
-93 Hilux
”Neitakk, æ kjør…”
1 Sperre bak
3 Litt større hjul
-93 Hilux
”Neitakk, æ kjør…”
Per
91791531 / 64988722
Mfa@offroad.no
-93 Hilux
”Neitakk, æ kjør…”
#50
<blockquote id="quote"><font size="1" id="quote"><b id="quote">Kopi av melding:</b id="quote"></font id="quote"><table border="0" id="quote"><tr id="quote"><td class="quote" id="quote"><font size="1" id="quote">Hummer`n har vel bare en nedgiringkasse ytterst ved hjulet og derfor sitter drivakseln utafor senter . Bærebrua ligger jo godt neddafor drivakseln så jeg ser ikke grunnen til å kalle det en portal...</td id="quote"></tr id="quote"></table id="quote"></blockquote id="quote"><font size="2" id="quote"></font id="quote">
portalene er nedgiringskasser på alle biler med portaler!!
hvordan akselen er opphengt forandrer jo ikke akselkonstruksjonen...
Tommy Olsen
Tommy Olsen
#51
Nei det er klart . Vil man ha portaler for i minske belasninga på resten av driverket så er det en ting men folket tenker vel bakkeklaring og sperrer når det gjelder portaler ? Og når det gjelder bakkeklaring er det ikke no særlig bedre klaring under bærebruene på Hummern med portaler enn f.eks Hilux IFS som ikke har portaler hvis bilene hadde hatt samme dekkstørrelse ? Utenom under diffen for der er Hummer høy under da men den har jo ikke no med portalen å gjøre . På en stiv portalaksel er bakkeklaringen god i hele bredden , nesten fra felgkant til felgkant .
