» Visninger: 343
» Visninger: 293
» Visninger: 11,332
» Visninger: 3,769
» Visninger: 6,469
» Visninger: 2,742
» Visninger: 2,669
» Visninger: 2,795
» Visninger: 2,835
» Visninger: 3,908
  rammenummer rocky
Posta av: eiesaren - 11.11.2010, 14:48 - Forum: Daihatsu - Svar (2)
hvor finner jeg rammenummeret på min rocky?
  Baksete til pajero 86mod lang type!!
Posta av: emilie06 - 11.11.2010, 12:51 - Forum: Mitsubishi - Svar (3)
Noen som har Baksete til salgs eventuelt hvor jeg kan få tak i???(helst Oppland) Eller er det noen annen type bil det passer fra?? [img]style_emoticons/<#EMO_DIR#>/wink.gif[/img]
  upgrades til jeep xj
Posta av: Madbutcher - 11.11.2010, 12:12 - Forum: Jeep - Ingen svar
Husker ikke om jeg har posta denna lista før.. men her kommer den iallefall
Masse nyttig info her [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
Suspension & Lift:
1. ZJ V8 Upcountry Coils = 1-1.5" lift
2. F-150/Bronco Coils ('79-ish) = 4-4.5" lift
3. S10 (P/U or Blazer) leaf packs (cut eyes off S10 main and bolt pack under XJ main) = 3-4" lift (may require use of shims)
4. Dakota Bastard Pack (do same as with S10 pack) = ~4" lift
5. JK shocks = slight mod to fit 2-4" lift (some dispute....see page 12)
6. MJ Shackles = 1/2" lift
7. Camaro Spring Isolators = 1.5" lift
8. Full size Blazer Bastard Pack (do same as S10 pack) = 4-4.5" lift (may require use of shims) may be stiffer than S10 leafs
9. ZJ spring isolators = stronger, metal core, can be stacked
10. GM fullsize pickup shackles ('95-99) = 1.5" lift, better shackle angle
11. Thunderbird Coils ('83-97) = 3-4" lift (varies in lift and softness by year and trim package)
12. Any 2.5" wide leaf spring can be used between to make a bastard pack (they may differ in stiffness and lift)
Brakes:
1. WJ brake booster
2. WJ Master Cylinder
3. YJ Brake Lines = 3-4" longer
4. Dodge Ram Van Brake Lines = 10-12" longer (for big lifts)
5. WJ Rotors/Calipers = bigger brakes and more stopping power (will fit 15" rims)
6. ZJ brake booster and master cylinder
7. XJ '95+ brake booster and master cylinder = dual diaphragm
8. Dakota Rear Softlines ('95-00) = 6" longer
9. GM C/K1500 Front Softlines ('90-95) = 6" longer
Axles:
1. Ford 8.8 inch ('97+) = need spring & shock mounts (3.55, 3.73, or 4.10, maybe LSD, Disc Brakes)
2. XJ I-4 & V6 = 4.10 gears (some have 4.56) may have vacuum discos
3. XJ C8.25 ('97+) = bolt in and upgrades to 29 spline (strength comparable to D44)
4. XJ D44 = found in some but not all '87-'89 XJ's with Towing Package
5. Lincoln Lockers = welded spider gears, operates like a spool, must be a GOOD welder
6. MJ D44 = need new spring perches and shock mounts
Front End & Steering:
1. ZJ V8 Tierods = beefier & bolt in
2. WJ Knuckles/Tierods/Draglinks = beefier and crossover steering
3. Durango Steering Box = beefier
4. 350 or 351 Power Steering Pump = helps with oversize tires (requires welding)
5. WJ LCA's = more tire clearance (some grinding required)
6. ZJ pitman arm = 1 inch drop over stock
7. WJ rear LCA's = replace XJ front LCA's, 2" longer to accommodate a lift, some grinding required
Engine Performance:
1. Newer XJ intakes (may require some modification)
2. Mustang 5.0 Injectors = near bolt in (have 4 holes instead of 1, more fuel, better spray)
3. ZJ V8 alternator = more power to run accessories (some grinding required) 136A
4. Ford Electric Fan ('90-95 3.8L Taurus, '87-93 5.0L Mustang) = replaces mechanical fan, more cooling (8C607)
5. 2.5L Dakota Alternator = bolt in, upgrades to 117A
6. Dodge Neon Injectors = better throttle response
Other:
1. '94+ V6 Dakota AX-15 = bolt in (but must use XJ bellhousing)
2. Lebaron or laser hood vents = help keep ur 4.0 cool
3. 97+ mirrors are direct bolt in to older XJ's and allow you to fold them in on tight trails.
4. MJ Bucket seats = tilt forward, bolt in to at least older XJ's
5. ZJ gas tank skid = can be modified to fit 97+
6. ZJ and WJ stock tranny coolers with stacked plates (even an upgrade for us with the stock fin style)
7. GM power antennas replace your broken XJ's with little modification
8. 5spd crossmembers give 3/4 inch tcase drop on autos with no loss in ground clearance
9. You can convert the closed system to open without replacing your radiator by using the fill cap from a 4.7 durango or dakota, cutting it into your upper hose, and replace your bottle with an MJ overflow tank or any that fit. Then cap off or eliminate the T'ed lines in the heater core.
10. XJ '97+ doors onto older cherokees = one piece windows and better mirrors
11. XJ overhead console = most commonly found in '00-01 or higher trim level, provides space for switches etc.
12. '97+ center console = can be made to fit '96 and older, gives you cupholders!
13.'96-00 Ford Explorer hatch shocks = lift your hatch about 3" lower but are beef (ever see one that doesn't work?)
  Girkasse 1989 Pajero 2,5
Posta av: 0le - 11.11.2010, 09:44 - Forum: Mitsubishi - Svar (4)
Noen som vet om girkassa fra L200 og L300 passer på en Pajero?
  wrangler
Posta av: 4x4lav - 11.11.2010, 09:28 - Forum: Jeep - Svar (1)
Åssen er 1997-2000 mod av wrangler.
er de galvanisert i karroseriet.
er det ramme på de?
  Varm eller kald garasje
Posta av: mhusby - 11.11.2010, 08:46 - Forum: Off Topic - Svar (5)
Diskuterer for tiden med svigerfar om hva som er best for bilen. En varm, eller en kald garasje.
Han mener en uisolert garasje som følger temperatursvingningene ute er best for bilen.
Argumentet han bruker er at det ikke er bra for bilen med temperatur svingninger, og at dette vil medføre rust.
Det saltes ikke her i området hvor vi bor. Er det bare med tanke på salting og rust du mener det er bedre med en kald garasje?
Jeg mener at det må være bedre med en varm garasje på flere områder en det er negative sider med det.
Tenker da på at det er større slitasje på det meste når det er minusgrader.
Det er jo ikke uten grunn mange ettermonterer motorvarmere på bilen der hvor det er sterk kulde.
Jeg tenker på at garasjen skal holde normal inne temp. +- 20 grader.
  Nye vinterlugger Gen3
Posta av: outback - 10.11.2010, 23:48 - Forum: Mitsubishi - Svar (2)
Noen som har prøvd dem, har kjørt på 5'ern lenge nå, men de er snart 4 år og bør vel skiftes. 4mm mønster i midtrillen og ca 7 ellers, og 99,99% av alle piggene er på plass men de begynner å bli glatte.
Så erfaringer med nye Nokian Hakkapeliitta 7 SUV, piggdekk.
Ellers er det noen i Nord en plass som trenger lugger til en arb.bil eller noe slik er det bare si fra. Hentes
  treg innslag av 4wd
Posta av: bimmer3 - 10.11.2010, 21:42 - Forum: Jeep - Svar (1)
hei, håper noen kan svare på detta.
når jeg kjører å setter wrangleren i 4wd så tar det litt tid før den slår inn i 4wd. hva kan detta vere?
hva er den runde dingsen som sitter på forrakselen (høyre side av diff), den det går noen ledninger ned til?
  Diagnose, har kjøpt OBDII kabel
Posta av: TruckerSveini - 10.11.2010, 21:26 - Forum: Teknisk & Mekking - Ingen svar
Har kjøpt meg diagnosekabel til PC´en.
Har ikke vært borti dette før, og lurer litt på om den er noe som er viktig i forbindelse med tilkobling. PC av eller på, tenning av eller på? Litt redd for å klusse til noe, men samtidig spent på å teste ut [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
Noen som har tips til programvare å bruke. Skal brukes på Mitsubishi L200 2005. Håper å få stilt på tomgangen, men tror kanskje en da må til med Mitsubishi sitt egen system, MUT-II/III. Noe må man vel få ut av vanlig OBDII og vel?
Mvh Sveini
  Nybegynner prosjekt 94mod d-cab. Hjul/bredding/trimming
Posta av: Yngve-xj - 10.11.2010, 21:12 - Forum: Toyota - Svar (3)
Heisann
Eg har kjøpt meg en gammal D-cab som nå er ferdig restaurert, så nå må den selfølgelig "videreutvikles"Wink Så tenkte eg skulle legge in litt bilder av prosjektet her:
Første ending bli hjul: 8X15 et-2 med 33x12,5" Og er storveis fornøyd med resultatet:[ATTACHMENT NOT FOUND]
.jpg   DSC_0728.JPG (Størrelse: 1.22 MB / Nedlastinger: 50)
