Dette er "ekstrautstyret" på min;
AG1 : ADJUSTER, FRT ST, POWER, 6 WAY DRIVER, SPLIT BENCH
AG2 : ADJUSTER, PASS ST POWER, 6 WAY, SPLIT BENCH
AJ1 : WINDOW TINTED, DEEP, ALL EXCEPT W/S AND DRS
AN3 : SEAT, FRT BKT, DRIV, PASS, ELEC BODY SUPT CONT
AT5 : SEAT RR, CTR, FLDG
AU8 : REMOTE FUNCTION ACTUATION, SPECIFIC FREQUENCY
AXP : VIN IDENT POSITION, MULTI-PURPOSE VEHICLE
AX4 : RESTRAINT, CONVERSION SEAT, MAN, EUROPEAN
A04 : WINDOW, TINTED, RR SIDE, RR
A31 : WINDOW, POWER OPERATED, ALL DOORS
BAG : PARTS PACKAGE EXPORT
B30 : COVERING, FLOOR CARPET
B39 : COVERING, FLOOR CARPET, LOAD FLOOR
B58 : COVERING, FLOOR MATS, FRT & RR, CARPETED INSERT
B85 : ORNAMENTATION, EXTR MLDG BELT REVEAL
CT1 : COUNTRY, BELGIUM
C25 : WIPER SYSTEM, RR WINDOW
C36 : HEATER, AUXILIARY
C49 : DEFOGGER, RR WINDOW, ELECTRIC
C5U : GVW RATING, 6800 LBS
C5U : GVW RATING, 6100 LBS
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
C69 : HVAC SYSTEM, RR, AIR CONDITIONER
DF5 : MIRROR I/S, R/V, LT SENSITIVE, COMPASS, O/S TEMP
DH2 : MIRROR, I/S FRONT VAN, LH AND RH, ILLUMINATION WITH DUAL
DK7 : CONSOLE ROOF, INTERIOR, CUSTOM
DL8 : MIRROR, O/S LH & RH REM CONT, ELEC, DEFOG
D07 : CONSOLE, FRT COMPARTMENT FLOOR, CUSTOM
EXP : EXPORT
E52 : DOOR RR, 83 INCH, WRAP AROUND
FF6 : ARM, LH, TORSION BAR SPRING ADJ (E)
FF7 : ARM, RH, TORSION BAR SPRING ADJ (F)
GT4 : AXLE REAR, 3.73 RATIO (DUP WITH 5 X 1)
G65 : LEVEL CONTROL MAN, SELF-ADJUSTING
G80 : AXLE POSITRACTION, LIMITED SLIP
JAN : PLANT CODE JANESVILLE, WI, USA
JE1 : BRAKE, SYSTEM, EUROPE
JH5 : BRAKE, HYD POWER, 4-WHEEL DISC, 7200 LBS
KG8 : GENERATOR, 130 AMP
KNP : COOLING SYSTEM TRANS, HD
K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K47 : AIR CLEANER HIGH CAPACITY
K53 : FUEL SENDER ASSEMBLY, ROBUST FUEL SYSTEM
LM7 : ENGINE, GAS, 8 CYL, 5.3L
MAE : MARKETING AREA, EUROPE
M30 : TRANSMISSION, AUTO 4 SPD, HMD, 4L60E, ELECTRONIC
NA7 : EMISSION SYSTEM EUROPEAN
NP5 : STEERING WHEEL, LEATHER WRAPPED
NP8 : TRANSFER CASE – (ACTIVE) – PUSH BUTTON CONTROL, 2 SPD
NZZ : SKID PLATE OFF-ROAD
N12 : REAR EXIT TAIL PIPE
QC3 : WHEEL, 16 X 7, ALUMINUM, SPECIAL
QMJ : TIRE ALL P265/70R16 – 111S BW R/PE ST TL AL2
R7K : CONTROL SALES ITEM NO. 36
R9Z : CONTROL SALES ITEM NO.100
SLM : STOCK ORDER, PROCESSING CODE
SLT : TIRE ALL, 31XlO.50RlSLT/C BW R/PE ST TL OOR
TR2 : LAMP,TURN SIGNAL, ENLARGED
TR6 : HEADLAMPS CONTROL, LEVELING SYSTEM, MANUAL
T2H : ORNAMENTATION, EXTR, EXPORT UNIQUE REQUIREMENTS
T2J : ORNAMENTATION, INTR, EXPORT UNIQUE REQUIREMENTS
T62 : LAMP SYSTEM DAYTIME RUNNING - DELETE
T79 : LAMP, FOG, RR
T84 : HEADLAMPS, RH RULE OF ROAD, E MARK RECTANGULAR
T89 : LAMP, TAIL & STOP, EXPORT
T98 : STAMPING VEHICLE IDENTIFICATION NUMBER
UC2 : SPEEDOMETER INST, KILO AND MILES, KILO ODOMETER, POSITIVE BIAS
UL2 : FREQUENCIES, EUROPEAN RADIO
UP0 : RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV, MUSIC, SEARCH, CASS, CD,
UQ3 : SPEAKER SYSTEM, PERFORMANCE ENHANCED AUDIO
UY7 : WIRING HARNESS, TRUCK TRAILER HD
VB3 : BUMPER, RR, STEP, CHROME, IMPACT STRIP
VC5 : LABEL SHIPPING, EXCEPT U.S., U.S. POSSESSINS, OR JAPAN
VD1 : PROVISION OPTIONS, EUROPE
VG3 : BUMPER FRT, IMPACT STRIP
VJ3 : LABEL, PLATE ECE APPROVAL AND VEHICLE IDENTIFICATION
VJ4 : LABEL, EXPORT CHILD SEAR LOCATION
VPH : VEHICLE PREPARATION OVERSEAS DELIVERY
VP3 : NOISE CONTROL – EUROPEAN PROVISIONS
VR7 : HOOK, TOW, SECOND, RR
VXX : BUMPER FRT,---DELETE---
VZ2 : CALIBRATION SPEEDOMETER A
V22 : GRILL RADIATOR, CHROME
V54 : LUGGAGE CARRIER, ROOF, PAINTED
V78 : VEHICLE STATEMENT DELETE
V92 : TRAILER PROVISIONS
XMJ : TIRE FRONT P265/70R16-111S BW R/PE ST TL AL2
X88 : CONVERSION NAME PLATE CHEVROLET
YD3 : FRONT AXLE, BASE EQUIPMENT FOR SCHEDULING, GVW PLATE
YD6 : REAR SPRING, BASE EQUIPMENT
YE9 : CONVENIENCE PACKAGE, COMFORT & DECOR LEVEL #3
YMJ : TIRE FRONT P265/70R16-111S BW R/PE ST TL AL2
ZMJ : TIRE SPARE P265/70R16-111S BW R/PE ST TL AL2
ZW7 : CHASSIS PACKAGE PREMIUM SMOOTH RIDE
ZY1 : COLOR COMBINATION, SOLID
1SM : PACKAGE OPTION 12
12I : INTERIOR TRIM, GRAPHITE (92)
122 : TRIM COMBINATION, LEATHER, GRAPHITE (2) (92)
14U : PRIMARY COLOR, EXTERIOR, LT GRAY MET (92)
6XK : COMPONENT FRT LH COMPUTER SEL SUSP (6XK)
7XK : COMPONENT FRT RH COMPUTER SEL SUSP (7XK)
Noen som kan finne ut hva de ukjente (???) kodene betyr for noe?
- - - Edit: Der gikk alle kodene inn - TAKK! - - -
Gøy å se at bilen min har disse kodene:
G80 : AXLE POSITRACTION, LIMITED SLIP (Eaton diff sperre på bakakselen) [media]http://www.youtube.com/watch?v=q-rQTHMVAuw[/media]
KG8 : GENERATOR, 130 AMP (Kraftig lading - bra siden jeg har booster i campingvogna for å alde vognbatteriet)
KNP : COOLING SYSTEM TRANS, HD (Er det ekstra gearoljekjøler på den? Må jo være bra siden det bare er en "60" kasse)
K47 : AIR CLEANER HIGH CAPACITY (Luftfilteret er ganske stort ja)
K53 : FUEL SENDER ASSEMBLY, ROBUST FUEL SYSTEM (Alt som er robust er vel bra...?)
NZZ : SKID PLATE OFF-ROAD (Er to tykke stålplater foran og under motoren, tunge å ta ned ved smøring av forstilling og motoroljeskift)
UQ3 : SPEAKER SYSTEM, PERFORMANCE ENHANCED AUDIO (Sikkert siden det er original sub i den)
UY7 : WIRING HARNESS, TRUCK TRAILER HD (HD Ledninger for tilhenger?)
Har din chevy noe spesielt ekstrautstyr?
Sjekk kodene i hanskerommet og bli overrasket...?
