» Visninger: 305
| Problemer med styring på Y60 |
Posta av: OnkelSkrue - 02.04.2013, 19:50 - Forum: Nissan
Trenger tips/gode råd.
Noen ganger vil ikke bilen svinge til høyre (dette er veldig skummelt) Det er akkurat som noe "butter" Har prøvd å demontere styredemper uten at det hjalp. Har mistanke om feil på styresnekke eller hjelpesnekke. Noen som har andre forslag til hva det kan være?
| jeep pcm fix |
Posta av: jan helge - 02.04.2013, 15:46 - Forum: Jeep
Jeep PCM (computer control unit) Issues
Before you submit to replacing the PCM (Powertrain Control Module) as the computer is properly called by Jeep/Chrysler, here is a quick tutorial on how to correct MOST problems that present as a defective unit. it requires a 30 watt (average) soldering pencil, some thin 60/40 ROSIN CORE solder (NEVER USE ACID CORE! it will destroy the unit!) and some Deoxit from Radio Shack. Deoxit is liquid magic! I have used it for decades in the electronics arena to stop erratic issues that were otherwise like chasing ghosts. It is fantastic for electrical/electronic connections in severe environments such as in an engine compartment. (No I dont own stock in the company, but wish I did!!!)
When you have your supplies together,remove the two screws in the cover and gently pry the tabs holding the covers on the PCM up. The small cover will come right off, the larger one will have to be gently pried off as it is actually the 5 volt regulator board of the PCM. This is the focus of our attention. turn it over and carefully clean any of the jelly potting compound from the solder pads of the connector strip that plugged into the other part of the unit. Now using as little solder as you can, carefully flow fresh solder onto each pad and the connector that is on the pad. It will take a bit of time to get it to flow due to the type of board material the unit is made out of so dont get impatient. when you ge a good solder joint move to the next pad inline, dont jump pads, the warming of the pard itself will speed things up. Be careful not to damage any of the components on the board or the copper traces that connect them.
When you have resoldered every pad, let the board cool, and treat the connector socket with the Deoxit... make sure yiu get it into the holes in the connector, and carefully treat the pins in the other half of the PCM where this connecter plugs into. Reassemble the unit, carefully bend the tabs back down into place. and replace the screws. WARNING! Some units have come frome the factory with screws that were too long, and eventually due to vibration shorted the unit out. I replace them with shorter sheet metal screws as standard operating procedure to avoid this issue, since I never ran into this personally.
Treat the external pins on the PCM with the Deoxit before reinstalling it in the Jeep. It is estimated that the repair I just outlined (except for the deoxit) will correct between 70-95% of all PCM problems. This is the same rebuild procedure that is done by the companies that sell the rebuilt units. As an experienced Electronics Engineer, I have gone the extra step and added the use of a deoxidizer on the connectors, which will protect the connections as well as increase their electrical integrity. I have personally used this cure myself on several Jeeps having been a longtime Jeeper with myfirst being a 76 Cherokee S. I currently have a 95 GC Limited, a 98 GC Laredo, and an 06 Wangler. You cant have just one!
As a side note on the deoxit...and this repair, my 98 GC was throwing O2 sensor errors with new sensors and irratic charging issues. I repaired the PCM as outlined and the O2 issues went away. I pulled the Alternator and took it to autozone (4 blocks from the house) and had it tested... it was fine... so I cleaned the contacts for the wiring harness and treated it with deoxit, and reinstalled... started Romero up (yes I name my Jeeps... Willie, Romero and TJ) the dash gauge indicated just under 14 volts and my DMM indicated a steady 13.81 volts and not a problem since... Like I said Deoxit is liquid magic. it should be in every tool kit if you deal with automotive electrical/electronics. It isnt cheap but it's worth it.
| Ansvarsfraskrivelsesskjema ved berging |
Posta av: tonjek - 02.04.2013, 02:06 - Forum: Chevrolet & GMC
Kan jo være greit å ha liggendes i bilen, til de gangene man skal trekke uheldige billister opp fra grøfta. Enkel og grei forsikring mot sutring fra billist med ripe i plasten. Husker det lå et slikt skjema ute på et av offroadforumene før, noen som har det?
| Trykk i kjølesystem |
Posta av: tactic - 01.04.2013, 21:48 - Forum: Jeep
Min trofaste følgesvenn Cherokee 2,5TD har hatt luft i magen en stund.
Bilen har gått over 20.000 med dette, uten at det har blitt hverken bedre eller værre.
Fyller ca.1 liter kjølevæske for hver 5-6.000 km
Ved lett kjøring minker ikkje nivå overhodet.
Derimot ved tung belasting minker det veldig sakte.
Løsner på påfyllinga på ekspansjonstanken så bobler det alltid litt..
Bil er 2001 modell og har gått 173.000
Nokken som har erfaring med dette, kan det være en dårlig toppakning?
eller er det sprekk i en eller flere topper ?
Alle gode svar mottas med takk!
